Evinrude200
Thread starter- Joined
- May 8, 2011
- 8
Hello have not been on here for awhile now but I have a 200XP and it will not shut off 1 side starboard shuts down when turn key off but engine remains running. Thought it was Power pack as I tested switch according to service manual and it tested good so new power pack and same result. This has never been a problem before put it away last fall all was good brought it out this year and chasing this wiring problem since. Any help would be great as I am running out of ideas and patience.
Installed new power pack. No change
Found 1 bad pin on blk/ylw wire from neutral switch now when I turn key off starboard side shuts off and when I depress the neutral switch motor kills out. Leaning towards neutral switch but they do not make that anymore.
Both small connectors in power pack bulk/ylw wires both show grounding out when key is turned off.
Not sure how to bypass or rewire neutral switch to try and isolate my problem any ideas or tests you guys may know of would be greatly appreciated
