89 Evinrude 110 V4 no forward or reverse.
dtooke
Hello everyone, just want to start by saying I'm new to this site but have heard great things about the knowledge of the users. So I picked up a older Skeeter over the weekend with a 89 110 Evinrude V4 that the seller said had issues with the lower unit. He told me he didn't know what was wrong just that it wouldn't engage into forward or reverse. I got a chance to look at it a little last night but haven't had a chance to hook up the muffs yet to listen to see if it makes any odd noises in there or not but I did remove the engine cover and could see the lever does move into forward/reverse so I'm thinking the cable isn't the issue. Also when in neutral the prop spins freely both directions, when in forward locks turning one way and free spins the opposite, and when shifted into reverse it locks when turned one direction and if you spin the prop the other way it locks after about 1/4 turn. I'll be honest I'm not all that knowledgeable on boat motors but I am pretty mechanically inclined so and advice would be greatly appreciated.
dtooke
Thanks for the quick response recerone. I'll do that after work tonight and post the results.
emdsapmgr
Also, look at the oil. 1. It should have about 26 ounces of oil that come out of the gearcase. 2. The oil should preferably not be black. 3. If there are a lot of large, metal shavings on the lower magnetic drain plug-that's a bad sign. 4. sometimes the P.O. has the shift linkage off. You might unbolt the shift cable on the engine side. Start the engine and see if it will shift by hand.
Fed
Just a tip, when you're selecting gears you need to turn the prop by hand to allow the dog clutches to mesh.
Either that or have the motor running.
dtooke
No Title
Thanks for the advice also Fed. So here is a picture of the drain screws. The one by my finger is the upper and the other is the lower. Lots of small shavings on the upper but not much on the lower. Oil looks a little dark but not too bad.
interalian
Odd to have mag plugs top and bottom - usually only the bottom one has it. That said, you have a lot of shavings there.
boobie
Do what Emds said about starting it up and see what happens.
dtooke
I'll pick up some new lower unit oil and a set of muffs in the morning and try Emds idea. Again guys I can't tell you all how much I appreciate all your help.
