89 DT 115 power tilt noise
stickbait
My tilt is making a squelling sound on the up and down motion. It has done this for a while now and I am baffled. It works fine but really irritating. I greased all the pivot points and trim fluid level is fine. Thanks.
deejaycee_2000
Re: 89 DT 115 power tilt noise
Mine does exactly the same ..... I just got use to it ... if it works leave it ...
Marc III
Mine did the same thing until it quit working. I believe it's the pump starving due to a restriction in the system or a faulty valve, but I'm no expert. I can't even get the unit out from between the mounts!
deejaycee_2000
Well mine has been doing it for the last 10 years and still working fine ....
