olbuddyjack
Thread starter- Joined
- Oct 23, 2003
- 318
89 Cobra 5.7, No forward or reverse.
I pulled the lower and found the drive shaft broken right behind the pinion gear.
Now for the big problem, How can I get it apart?
In order to get the pinion gear out I need to turn the driveshaft to remove the pinion nut and theres just nothing to get ahold of. It can't come out with the nut and shaft stub together and the prop shaft and gear won't come past the pinoin.
It looks repairable, I can't see any gear damage or such but I need to get the parts out to make a good inspection.
Plus I want to find out why it broke. No strike or prop damage. The engine just freewheeled pulling to plane.
I have means to weld the case if I need to drill or cut the bullit anywhere to get the parts out.
If anybody has any experience or ideas I'm all ears!
