89 - 60hp Johnson Tracker
clockese
Would any one know what the correct pitch for the boat and motor package would be. I have an 89 Tracker 1600 TF glass bass boat with a 60hp Johnson Tracker. I am trying to keep it original and I am not sure what prop that motor came with new. Would anyone know? Any and all help would be appreciated.
steelespike
Re: 89 - 60hp Johnson Tracker
Do you know the present prop size and the max rpm and speed?
Numbers are usually under the prop nut.Orioginal prop may not necessarily be the best prop.
NADA chart says boat is Aluminum? 830lbs. If its glass I would put it closer to 1100.
I would guess the aluminum would be a 17" pitch, Glass a 15.But that could
change drastically depending on the configuration of the hull.
