numbersguy
Thread starter- Joined
- Sep 1, 2010
- 22
Thanks to all of you who helped me through the VRO oil alarm and temp alarm issues VRO is working and I replaced the thermostat and temp sensor and found a short in the temp circuit too. I got it all working and it actually ran decent over the weekend. But now I have a new problem.
After running the motor around the lake Sunday evening I raised the engine up out of the water using my power tilt. It sat in that position over night. Monday morning I lowered the motor into the water and started it up but then it began raining so I shut it off after it had warmed up and left the motor in the down position. After a couple hours the rain slowed so I went out to raise the motor and cover the boat. When I raised the motor I noticed oil/fuel dripping off the bottom of the lower unit into the water. I'm not sure where it was coming from. It stopped after a couple of seconds, but is this normal? If not what could it be? It created a film on the water about 4-5 ft in diameter.
I tested the compression on Saturday and had 100 and 95 psi in the 2 cylinders. Not as high as I had hoped but it is 22 years old and I'm the 3rd owner.
Thanks for your advice on this.
Numbersguy
Numbersguy
