89-125 force, trim/tilt
wajajaja
tilt worked when i picked up the boat, now does not alongwith some other electricals that worked, will start tracking down the tbl, looking for quick info on where will i find the fuse/or ckt breakers and relays, are they burried in the harness somewhere in the boat.bayliner cuddy, or under the hood. i do have the books, seloc,and clymer. probly need to read closer <br />thanks .walter.
roscoe
Re: 89-125 force, trim/tilt
If several items are now not working, check the ground and power cables, starting with the battery connections.<br /><br />The relays or solenoids(depending which tnt system you have) are under the engine cowling.
wajajaja
hi, roscoe, tbl is solved, found one of the relay was rusted to where it shorted out the make brake with high resistence that would let the motor work in either direction, or blow the fuse. <br /><br />i believe it is a automotive / wasnt sealed, and was held in place with tie wraps. must of worked for a long time to be so rusted, the return spring crumbled. <br /> got new ones on the way<br />thanks.
