89 125 force tilt and trim
Chris125
I just recently pulled my bayliner out of the water and the motor will tilt all the way up but will not tilt down at all. switch clicks in but does not make any noise for the down tilt but for the up it works just fine any help pls?
cyroute
Re: 89 125 force tilt and trim
Swap the relays out if the down works and the up doesn't you have a bad relay. I have the same issue but mine works most of the time. I was told to replace both of them at the same time not sure you need to do this but I also heard the relay that is actually bad is the opposite of what you would think. I'm just going to replace them both. If you search for the part number on the top there is a place in PA that has them for like 11.00 (link is below). They happen to be less than 10 miles from where I live so I'm going to go this week and pick them up.
http://www.rallylights.com/
Joe
