Re: 88hp johnson
flynn,<br /><br />That is one of the most durable engines ever made.<br /><br />They are thirsty though. Expect to use six gallons per hour at a moderate cruise 3500 to 4500 rpm.<br /><br />Just make sure the compression is good. All cylinders within 10% of each other. Also check the lower unit (propeller gearcase) for water.<br /><br />Make sure the engine is propped correctly. It should be able to turn 5500 rpms at wide open throttle. Any less, it is lugging. That engine doesn't like that.<br /><br />Most likely the best prop for that set up is a <br />13 1/4" X 13".
