Having a tough time with an 88 mercury 60, 3 cylinder, 2 carb engine.
Engine starts fast, but dies and will not hold revs. Sometimes I can almost get up on plane and then it bogs out and stalls.
New spark plugs
New diaphragm gasket kit installed
New fuel tank and hose
New inline filter on engine.
-Engine acts no different when I try to pump the prime bulb when taking off or trying to hold rpms in neutral.
- I have taken the cover off so I could see the carb inlets. Pumped the primer ball until it was stiff, no sign of leak and primer ball stayed stiff.
After running I took the plugs out and they all had fuel on them. The bottom one may have been slightly dirtier.
Any suggestions on where to look next would be greatly appreciated!
Thanks,
Andreas
New spark plugs
Thanks,
Andreas
