Just bought a key west with an old SPL 88 Johnson V4. Motor hadn't run for 1.5yrs. Good compression (120s), started up with new fuel but cooling test shows large variance in temp from one side to another. R side getting to 170 while L side getting to 130 @ 3000rpm for 5-7min. Good pea stream although slightly weakened at higher RPM. So the thermostat is bad on the hot side right? WRONG! This motor has nothing sitting in the thermostat unit, no springs, thermostat or even the little white plastic plugs. Left me scratching my head. Tried to run the motor with thermostat housing off but no pressure or vacuum present to push water stream, so that's pointless. I have good water flow out of all the outlets and even cleaned them out with plastic weed wacker line. I have the original repair manual but it doesn't help explain the coolant anatomy outside of cylinders. Am I to assume there is a blockage on the hot side somewhere around the cylinder heads? The upper hot side (right) does get hotter than the low. To make matters more interesting the thermostat cover and plate was completely corroded and crumbling around the outer bolts, with some corrosion to the lower main/ exhaust unit as well. The gaskets still seal everything however and I have a new thermostat cover and backing plate.
What to do next? Do I pull the lower unit and change pump and impeller or open up the cylinder heads or both. I really don't want another summer project, might be time for a new motor here. Motor is 10yrs older than boat.
