88 Johnson GT 150 WONT SHUT OFF/HELP!!
87Chap
i put my boat on the trailer the today and turned the key off and my motor would not shut off and i have no idea what would cause this. it has never done this before and i had turned it off and on all day long and this occured the last time of the day when i really needed it to shut off :confused:
i had to clamp the fuel line to get the engine to finally shut off
any help would be great! thanks
crxess
Re: 88 Johnson GT 150 WONT SHUT OFF/HELP!!
First, Never Ever Starve the motor to shut down. You can cause serious internal damage from leaning out.
Either choke it to flood/stall or cover the air inlets on the carb.
Sounds like your switch may be dirty. switch normally shorts ignition to ground when turned off. Could also be a loose wire or corroded connector somewhere between. key and motor.
jonesg
they can run even with the red plug disconnected,
even with the battery disconnected,
decarb it.
87Chap
what do you mean by decarb it?
lindy46
I would suspect a bad ignition switch or bad kill switch (if so equipped) or a loose/broken wire.
cdoliver
decarb it.
I hardly think decarbing will cure this problem...as already stated, problem most likely your key switch or connections on the switch or a problem with the ground at the key switch.
emdsapmgr
I have seen this somewhat rare situation on a twin power pack V6, (like yours) where one pack was defective and would not respond to the ground from the key switch. When shut off, only one pack was grounded-the engine dropped an rpm or two and kept running on the other pack. Turn the key back on and the engine picked up a few rpm. Solution: replaced the pack.
