88 johnson 40hp vro conversion
bigboy71
I have a 88 Johnson 40hp with VRO fuel pump and would like to change over to standard pump and mix my own fuel. Anyone know what standard pump will work and if it is a difficult job? ANY help would be appreciated1
Honorary Supreme Mariner
Find the pump for a 2 cylinder 48 HP model.-----Multiple years of that model.-----It bolts to the side of your block with 2 screws and a gasket.----Remove the plug in between the screw holes for the pressure pulses.-----Rearrange hoses to suit.----Plug the pulse port where the VRO got it's pressure.
flyingscott
If your VRO pump is still working keep using it. Just disonnect the oil side and use it as a pre-mix pump.
bigboy71
That’s where I am running into the trouble. I have purchased a pump that they said will work. However my VRO pump has the rubber mounts and does not attach to the block. I am unsure of where the new pump should be installed.
