Daytrip5692
Thread starter- Joined
- Jul 4, 2010
- 1
I have a Blue Fin with the Force 50. This has sat inside for the past 7 years. Finally got it out this year and looking to get it back in the water. A couple of questions. One, what are the correct spark plugs needed? It currently has NGK, although I can't remember the number. Two, should it be de-carbed as it has sat for so long? If so, what is the best way to go about this? Ive had it started in the driveway in a barrel of water. Even after all this time, with fresh gas and the original plugs, she fired right off after a couple of cranks. Couldnt believe it. I still had decent water flow through the engine and hope I don't have impeller issues. I've changed the lower gear lube, still in good shape, no leaks, no water. Any other words of wisdom before I set out?
