ahickman
- Jul 5, 2012
- 79
Realized today that I have a significant water/exhaust leak in the gasket which relieves exhaust through the nostrils midway up the shaft. At WOT the water and exhaust is formidable. Looks like the PO used duct tape to patch it once before. My questions are as follows:
1. How diffucult is it to replace the gasket. Looked at a few postings and read that the "powerhead" must be removed. Is this correct? Is the powerhead the motor?
http://www.crowleymarine.com/index.cfm?fuseaction=product.display&Product_ID=6932
2. Depending on the work involved in the actual replacement, I am thinking about a temporary fix using a rubber sealing tap that I use on 1/2" coax lines used for radio antennas. It is thick, pliable and heat resistant. Just wondering how hot that gasket gets. Can't be above 180 degrees, can it?
Aaron
Aaron
