88 evinrude needing help
fancy1
We just got a 1988 Evinrude 140 hp V4 with a VRO however the VRO had been disconnected. The first time we took it to the lake it ran great, the second time it ran great until we stopped an fished a few hrs then when we started it back up it did fine for a few minutes then started running rough and skipping and then cut off, got it running again but had to go slow to keep it running. Replaced the Fuel/Water separator filter, fuel pump, hoses, and sparkplugs. took it back to the lake today and at first it did good then it started doing the same thing just not as bad. It seems like if you keep it at 1/4 to 1/2 throttle it runs smooth but seems to surge, if you put it to full throttle its almost like its the same as 1/4 to 1/2 throttle if that makes any since. It runs mixed gas at the 50:1 ratio. and the serial number is G1444479. Model number E140TLCUA. Thanks in advance for any help or ideas you may have
Joe Reeves
Re: 88 evinrude needing help
Does the fuel primer bulb have a tendency to go flat when this problem pops up? (fuel restriction)... If so, check the following:
(Fuel Anti Siphon Valve)
(J. Reeves)
Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vacuum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.
NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models.
The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
The above procedure will cure a restriction problem with the anti siphon valve as stated. BUT, it may also allow fuel to drain backwards to the fuel tank when the engine is not running (siphoning backwards) due to the fact that the carburetors/fuel pump etc are higher than the fuel tank. This condition is not an absolute as the valves in the fuel primer bulb usually prevent this backwards siphoning problem. However.... if this does take place, the cure would be to install a new anti siphon valve.
NOTE: There has been cases when the output valve in the fuel primer bulb would come apart, and the inner portion of the valve would actually reverse itself and be drawn back into the primer bulb's output valve body. This in effect would create a shut off valve and result in a fuel restriction. If this is the case, you should be able to feel something laying in the bottom of the primer bulb when held horizontally.
Do the basic trouble shooting procedure as follows:
(Compression & Spark Test)
(J. Reeves)
1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi (somewhat less on the smaller hp engines) and even on all cylinders.
2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On magneto ignition systems.... and also the Battery Capacitance Ignition system OMC engines from 1968 to 1972, set the gap to 1/4". On the solid state OMC ignition systems from 1973 to the present, set the gap to 7/16". The spark should jump the gap with a strong blue lightning like flame..... a real strong blue snap!
NOTE: Checking the spark via using the spark plugs is a waste of time and proves nothing. The above stated gaps must be used for a proper test.
If there was no spark, on engines from 1973 up (If the electrical plug exists), disconnect the RED main electrical plug at the engine. Remove the s/plugs. crank the engine via the starter solenoid (jumper bat term to small 3/8" term nut, not the ground nut) and observe spark. If spark is now okay as stated above, the usual cause is a shorted ignition switch BUT that black/yellow wire could also.be shorted to ground at some point wthin the wiring harness.
For the later model engines where that large RED electrical plug was discontinued for updated electrical connections, find the black/yellow wire leading to the powerpack and disconnect it to run the above ignition switch/wiring harness test.
If the above checks out as it should, and the engine dies out when throttle is applied or won't idle, it is usually due to one or both of two things. The carburetors are fouled, in which case the cure would be to remove, clean, and rebuild them..... or the timer base under the flywheel is sticking which would result in a retarded spark. If the engine will not fire/start at all even though you have the proper spark and compression, it's usually due to fouled carburetors.
To check the timer base for sticking (Engine Not Running), spin the prop to align the shifter dog with forward gear and while doing so, put the engine into forward gear. Now, while watching the timer base, slowly apply throttle clear up to full throttle. The timer base should move smoothly all the way up against the black rubber cap that is atached to the end of the full advance spark setting screw. If the timer base sticks, find out why and correct that problem.
Usually any sticking of the timer base is caused by one of the four retaining clamps being slightly too tight. Putting a very thin washer under the clamp cures that problem. Some boaters use a thin screwdriver to bend the clamp upwards slightly but I prefer the thin washer. The sticking can also be caused by having a faulty stator start to melt down, resulting in a sticky substance dripping down on the timer base nylon retaining ring.
Letr us know what you find.
fancy1
ok we check the compression and all 4 are even(95) which is within range for this motor. Check for the spark and got it on all 4. It doesn't have a bulb it has an electric fuel pump.
boobie
Do you use the electric fuel pump just for starting or does it run all the time the key is on ??
fancy1
it runs the whole time the key is on
boobie
If it does, it's a fire hazard !!!
