88 evinrude barely charging
Racinmason03
I just put a new stator on my 88 evinrude and now I'm barely getting it to charge. It has power tilt and I was sold a 6 amp stator. When I have it running it'll stay around 12.2 volts and when I rev it, it does not go up. Is it different from a car? I know a car goes from around 13.5-14.2 volts
ob
88 year model? 88 HP? What year and model number?How high did you rev it? In water or on the hose? And yea an outboard charging system behaves much like a car in that the voltage will increase as the rpm increase. Mine doesn't increase measurably until after 3000 rpms. Of course I don't rev it that high on the hose.
oldboat1
If you have an 88 hp, I believe it has a rectifier -- no rectifier/regulator. If so, it would be about a $30 replacement item -- can also be tested with a multimeter. It's the rectifier that usually yields charging issues (also wonky tach operation).
David Young
Yep "if" you have a rectifier, buy a new one. I had the same problem, a new rectifier fixed it :)
