88 evinrude 8hp no start after winter storage
jlayman0270
88 evinrude 8 hp. I bought a 14 foot aluminum boat last summer and ran it for about 6 trips fishing before I put it away for the winter. I didn't do any of the good stuff before storage like running the motor until it's dry, etc. (ignorance). , So this summer, when I tried to start it, It started but only ran for 30 seconds, then died. I checked out the plugs and wires and found the plugs were incorrect (not the recommended manaufacturer plugs for this motor). I changed the plugs and got fresh gas and 2 cycle oil (50:1 mix) and tried again. This time no start or even so much as a sputter. My dad has the Johnson version of this engine and he said when his did that he took it to the shop where they replaced the fuel pump, so I got a fuel pump and the problem didn't go away or even improve. Later I was told to try cleaning out the carb with spray and put some cleaner in the tank to help it clean all the gunk out. I did so and it started and ran great in the tank for about 5-10 minutes. I revved it high a couple times, put it in fwd and reverse, etc. Then shut it down. About a week later at the dock no start. A quick sputtering start but then died quickly. I dont want to take it apart more than I have to and I cant afford to pay a shop $200 to fix it. Troubleshooting suggestions?
ondarvr
It's common for symptoms like this after it's been sitting for an extended period of time.
Clean the carb, that means taking it apart, it's very easy.
oldboat1
If there is some varnish in the carb from old gas, the only good way to clean is to pull off the carb, disassemble and clean it.
Can try some more carb spray on the chance that you cure what ails it. You have a low speed needle at the top of the carb -- may have to remove the air silence on the front to get at the needle. But if accessing the needle, can remove it and spray carb cleaner in that way. At the bottom, you might remove the fuel line and spray carb cleaner in there. Doesn't take much to cause problems, but can be hard to get at easily. If you remove the low speed needle, you will need to reset/readjust it for running .
Joe Reeves
The carburetor float needle valve may be stuck... the high speed jet that screws into the side of that plastic housing in the bottom portion of the carburetor upper housing is no doubt clogged due to sitting... clean it
jlayman0270
Great suggestions! Thank you. I sprayed more cleaner in there after returning home and it would fire up from the spray, like a starting fluid but then die immediately again.
Joe Reeves
Spraying anything into the carburetor throat, if that's what you're speaking of.... that does absolutely nothing to the carburetor. There are no short cuts. It has to be taken apart.
