88 evinrude 15 hp dies when i shift into gear
metalboyroy
hi new to this site recently bought a boat with a 15 hp evinrude first time I took it out did great no problems.
took it on the river two days later and it dies shortly after shift into gear both forward and reverse any suggestions
on where the problem might be ?
Honorary Supreme Mariner
You are mixing gas and oil at 50:1 on this ??-----Start with a compression test and check for spark on both leads.---Might be running on one cylinder.----Water pump has been looked at and replaced I hope !
coolbri70
check your compression and spark, check your fuel line. spin your prop by hand in neutral make shure its not dragging with fishing line or something wrapped on the shaft
metalboyroy
yes water pump is new will, check compression, spark and fuel lines and yes its 50:1 thanks will post back with results
metalboyroy
I started with a compression test tested good checked spark, good spark but had old spark plugs so replaced them,
it still died so checked lines and fuel pump they were working fine ,so I thought about some other threads I read about
about gummed up pins so i took the idle pin out marking it and counting the revolutions then used carb cleaner to clean it
and the port it came out of,reinstalled it and low and behold it started right up shifted it and it did not die , let it sit for quite
a while just in case it was a fluke and tried it again...its working fine thanks for your help
