88 evinrude 100 xp (Rebuild)
Flats Fishing Goon
Starting the rebuild on my 88 evinrude 100 xp, it's a v4 crossflow motor and so far I've got the entire powerhead removed and stripped down to the crank and block. If anyone has any suggestions Im all ears! Same with any questions. I'm super stoked about this project and will be posting pictures of the before and after. For some reason I'm not able to upload photos at the moment.
interalian
Do you have a factory service manual? Good thing to have for all the specs and details.
If you want, wade through my rebuild post linked in my sig - I did a full rebuild last year.
Flats Fishing Goon
Awesome! Great source of information! I did purchase a Seloc book for this rebuild. My biggest concern right now is whether or not this block needs machine work. I had a piston actually break in the cylinder damaging the head. But visually the cylinder walls and ports look to be ok. During your rebuild did you have the block hot tanked or cleaned in anyway? Wondering if its something i should do while its bear.
interalian
My block was degreased at the machine shop but didn't need much. Note there's more to knowing if you can re-use the standard bore than just seeing if the holes look OK. They need to be measured for out of round, taper, and wear. I used a motorcycle shop to bore out +30mil - it would have cleaned up to +20 though and I can't see ever wanting to rebuild it again - should last another 30 years the rate I use it.
If there are a few dings on the head it'll run just fine. Make sure there are no chunks of ring embedded in the head (use a magnet), and dress any rough spots with a grinder. Re-surface the heads and re-use. No big deal.
Flats Fishing Goon
Stopped by the machine shop today with the block for a qoute and some questions. Trying to do this rebuild on budget. The machinist told me $50 to hot tank everything and for the bore $50 per cylinder. Seems kind of high if you ask me..
interalian
Boring at $50/hole is more than fair. My machining bill was C$400+ in Edmonton.
