88 120 looper dead cylinder
Jeeper33
I need help! I have a 1988 120 looper vro bypassed has one cylinder that will not light. So far I have done the basics. Ie. Cleaning all grounds swapping carbs and coils checked timing recirc. Valves and primer system and all came back good. The top port cylinder has a strong blue spark that's jumping the 7/16 gap but still will not light. The compression on all cylinders are 125 + - 3lbs. I have replaced the stator the flywheel reeds and the cd pack with no luck still the same problem. Any ideas?
oldboat1
Just for grins, check continuity of each plug lead, boot to boot.
Jeeper33
Oldboat1 I have replaced the leads. It's getting good strong spark on that cylinder it just will not hit. If you remove all plug wires except the cylinder having issues and try to start it it acts just like it would if it had very low compression. It will try to hit but never catch up.
flyingscott
What are flywheel reeds and have you checked the carb sounds more like a fuel issue than electrical.
Honorary Supreme Mariner
Some typos in post # 1 -----Have you looked at crankcase compression for that cylinder that is dead ?
oldboat1
Additionally, could be a bad plug. You might test the dead cylinder with a known good plug.
Usually, folks have to be prodded to use a spark tester. It sounds like you must have used a tester, though, if you know you have a 7/16 inch spark. So the ignition may be doing its job -- up to the plug.
Jeeper33
Sry flywheel and the reeds.. and yes I have a 4 wire tester. The compression is over 120 on tha cylinder. I have tried swapping carbs with a known good one.. I know it's not healthy for one but I even tried a very small amount of starting aid in that cylinder with no change. It's driving me nuts I'm a professional mechanic of 15 years and haven't had anything stump me like this
Jeeper33
I have got crazy and checked the play in the crank and rods/and wrist pins thinking maybe it had some wear but everything is in good shape
Have you looked into the issue of low crankcase compression ??
oldboat1
well, hate to see a guy go through all that over what turns out to be a bad plug. Think if it were me, I would switch it out or ground it on the block to make sure it's firing -- seems a little strange there is nothing using starting fluid, given the measured spark with the tester. Kind of a unique circumstance.
Additionally, is the starter spinning it fast enough?
Can check for crankcase leaks by carefully spraying a little carb cleaner at the joint, also low to try and check the crankshaft seal -- should get a change in engine speed if a leak is present.
Faztbullet
You sure its a 88?? The small bore 87 had issues as the bridged port would scuff exhaust side of piston and stick rings. The cylinder would have compression but so much blowby it wouldn't make power
Jeeper33
Anyone know if there is enough room to remove the rod through the front half or do you have to split that one?
Jeeper33
Ok for anyone flowing this post still I finally solved the mystery. After pulling the port head I found the liner on the top cylinder turned almost completely closing the intake ports. After a teardown and some heat I was able to re seat the liner. I'm guessing it was ran hot at some point letting the thing turn. All well and it runs great. Comfortably pushing my 18 ft cc at 40 + at 5100 with a 19p. Thanks to all the advice along the way
boobie
That's a good one. Guess that's why we say when you have a bad runner ,"pull the head" !!
