hankll
Thread starter- Joined
- Sep 10, 2006
- 224
Recurring problem: No fire on starboard bank, all or some of spark plugs (2 per cyl)
Yesterday after thinking I'd found problem, went to lake, motor missing again, put it back on trailer - go home. Today start checking inside CDI box. everything looks alright. Checking spark by putting a timing lite onto each spark wire. Sometimes getting spark, but not all the time. Then I discovered I was getting spark at the spark plug wire connector until I hook timing lite spring connector to spark plug, then nothing. Inside CDI box , two primary wires into coil and 2 secondary (spark plug wire) out to the plug. The primary wires are solid black and mixed stripe/black. Noticed the solid black wires on port side were hooked to ground, and mixed stripe/black was hooked to color wire (from CDI unit) according to which cyl was for that coil. Starboard side was hooked in reverse.
Question I have: Does it matter how the wires are hooked up to the CDI unit, or is that the reason the spark plug seems to be grounding out on the spark when connected to the plug but is sparking ok when not hooked to the plug? Have I found my problem? My mechanic may not have been so good after all!
