87 stratos livewell replacement any info would help thanks
mpwente
hi i have a 1987 stratos 169v and the front livewell got damaged..(guessing the previous owner put a ancor or something in there and chewed it up..anyways ive noticed when i let my rear plug out i tend to get water in the back of my boat..im guessing the livewell finally let loose and is leaking down through the bottom or the line that runs from the tank to the back of the hull is weak and needs replaced..can anyone help me with some ideas on how to go about replacing the livewell and the line? ive reacently started working on the motor and im interested in learning as much as i can on my boat and how everything works..any help would be appreciated
thank you
matt
