87 Searay tilt trim problem...
love1u0
I took my boat out for the first time and everything went great.<br />Got it back to my house and tried to raise/lower the outdrive and all I got was clicking.<br /><br />I cleaned the wires that are plugged into the solenoids, but that didnt help.<br /><br />I went down to my local Napa autoparts thinking I would order a couple, that is until he told me they were 300.00 each!!<br /><br />Is that a correct price? I did some searches and thought they would be around 30 each. :confused:
Re: 87 Searay tilt trim problem...
I'm afraid I Don't Understand..........<br />What Are They ??????????
love1u0
They are the two solenoids that activate the up and down movement of the outdrive.
Jump accross them to see if it's the solenoid...<br />It Could be the motor....<br />Is the Battery Up to Snuff....<br />Rarely do Both solenoids go out at the Same time....<br />What Drive are we working on Anyway ???
love1u0
Originally posted by Bondo:<br />Jump accross them to see if it's the solenoid...<br />It Could be the motor....<br />Is the Battery Up to Snuff....<br />Rarely do Both solenoids go out at the Same time....<br />What Drive are we working on Anyway ???
Im not sure what drive it is because Im new to this boating stuff. It is a 1987 3.0 4 cylinder.<br /><br />everything seemed to be working fine on the lake, got it home and it wont raise or lower....I hope its not the motor :(
Walt T
There now that wasnt so hard. Apply power to the motor and see if it runs. If not check ground, and VERIFY it's a good ground. Then make sure the solenoids are grounded good too. Then see it it works. If not you get to follow the power. On the solenoids there are two big posts and two small ones. One of the big ones is live at all times. One of the small ones goes live when you hit the trim button. The other small terminal is for ground. When the little one goes live BOTH big terminals should be live and the motor should run. If they are live and the motor terminal is live, then you either have a ground problem at the motor or a bad motor or a stuck hydraulic pump. This is the same for both solenoids.<br />Give it a try, it isnt difficult. Remove the solenoids and take them to NAPA and they can match them up for you. If the motor is bad you may be able to have it repaired at an automotive starter and alternator repair joint. If the Hydraulic unit is bad, then it's gonna caost about 500 for a new one.
love1u0
I wiggled the wires that go into the motor and it started working. <br /><br />Back to my original question..<br />I went to Napa yesterday and they wanted 300 dollars each for the solenoids. Is that wrong in there computer?<br />Shouldnt they be around 30 bucks?<br /><br />Now, is it that hard to answer my ORIGINAL question??
fireship1
Hello, I can't honestly say how much each they cost. $300.00 each sounds kinda steep to me. I know this though, know you need them before you buy them. A little time and troubleshooting costs you yourself nothing. You have nothing to loose and everything to learn. However running out to buy parts when you don't really know what is wrong is EXPENSIVE and FRUSTRATING! Listen to Walt and the other guys here. The advice they have to give is PRICELESS! Many of them are experts. They fix this kind of stuff everyday. Besides, many electrical parts are non returnable. If you find you don't need them, your stuck with them! Take your time and look the system over. If you are patient, you WILL and CAN fix it! Good luck!
Walt T
No, they don't cost 300 bucks unless you went into the store with the attitude you display here.
affa
Hi<br />Have you checked your trim limit switch?<br />If not try to disconnect it and put the wires together without going thru the switch.<br />Regards<br />Affa
love1u0
Originally posted by DieselWalt:<br />No, they don't cost 300 bucks unless you went into the store with the attitude you display here.
dude, go screw yourself....hows that for attitude<br /><br />You started it by this comment "There now that wasnt so hard. "<br /><br />Just becaues I didnt understand his question you didnt have to say that.<br /><br />The question I had asked was how much do these solenoids cost, not please help me fix my problem.<br /><br />Now to Bondo..<br />Instead of quoting part of my post and asking a stupid question like "What Are They?????", maybe you should read the whole post over again and you will see that "They" are solenoids....again, my question to begin with.
love1u0,<br />Well,<br />I'm siding with the Rest of the Gang here.......<br /><br />We Can't answer Questions Without Quality Information.......<br />It Took SEVEN(7) Posts to find out it's a Merc.........<br /><br />In your 1st post You're Talking about,<br />Trimpump,<br />Wires,<br />And Solenoids..............<br />AND, No Mention of WHAT BRAND of Outdrive We're Talking About....<br /><br />$300. for a trimpump Means your NAPA guy is a Good Friend.......<br />$300. for Both Solenoids tells me, You walked in there Displaying the Attitude You're Showing Here.....<br />SO, As I sit here with My NAPA Parts,+ Pricing Catalog.......<br />
:rolleyes:
Walt T
Hey sorry if anyone took offense at my 'Wasnt so hard" comment. I was just kidding around didnt mean to step on any toes. Easy to forget people don't see humor the same way.
Hey, Not Your Fault, Walt....<br />I can See Why NAPA wanted $300. for solenoids....<br />It Took 7 Posts to find out it's a Merc....<br />I Guess I'll have to go find a Crystal Ball, Just so I can Hear what He's Thinking, instead of what he's NOT Typing.....<br /><br />Here We are Offering a FREE Service,<br />And this guy comes Off at Us...... :mad: <br /><br />IF he was a Paying Customer, I MIGHT take a little $hit.....<br />But, Not Here.... :D
rodbolt
hello<br /> wow at least it was D W that got blasted, just tell chuckle head to put any kind of solinoid on it and make motors sounds and it will be ok. after all parts is parts. we take all them little parts and make a big part. and after all the good info ya got here.<br /> yall have a nyce day now ya heah :)
Clams Canino
On between killing each other it might be good to remind him that the *exact* symptoms he describes also could be very likely caused by a dead/weak battey. :D <br /><br />That's the *first* place to start particularly since he's new to the boat and the condition of the battery and alternator is totally unknown.<br /><br />Put the battery on a charger to full then try the trim. OK?<br /><br />-W
