I've aquired a 1987 50 hp evinrude that I want to put on a 76 14 ft chrysler hull. Currently, there is a 45 hp chrysler hanging on the back of the boat. The control box and cables for the 'rude are a LOT shorter than the cables for the chrysler. <br /> 1. Should I be able to to just change the rod ends on the chrysler cables to make the rude work?<br /> 2. Chrysler has batt, points, coil type ign. Rude, is different. What wires go where on the ign switch to make it run?
