Hi. I'm new. So please be gentle.
I recently removed the lower unit and replaced the shift shaft seal in my 87 Merc 35 HP. I was careful to keep the shaft in place when I removed the bushing, made sure it didn't move clockwise or counterclockwise. Before reinstalling it, I even made sure that it was still in neutral as when I removed it (prop spun freely), one turn counterclockwise put it in forward (prop clicked when moving counterclockwise), and one click clockwise from neutral put it in reverse (prop wouldn't move). Then, I reinstalled it in neutral (shift shaft was in neutral). I tested the controls. Moved lever to forward (prop spun counterclockwise with the same clicking) and then back to reverse (prop stayed put). Shifting the lever was noisier than before I did the work, but everything seemed to check out. THEN I started the motor. While the control lever was in neutral, the prop ran as if in forward. When I pulled the lever to neutral it grinded a bit and the prop started spinning the other direction. Does anybody have any idea what is going on, or how I should proceed to fix it. Thank you very much for any input.
