I was told I needed 2 quarts to change the oil in the lower unit of a 87 Johnson 70hp outboard.<br />I pulled the upper and lower plugs on the lower unit and 1pt of oil drained out. I can put back in 1pt of oil and it starts draining out, indicating its full. Is it true I should require 2qts of oil for this lower unit?
