87' johnson 60hp
crazy eddy
left fuel can closed and in sun expansion created pressure and a leak at fuel pump looks like a small pencil eraser sized cap that appears to be leaking after I applied some pressure to cap and running on ears/hose it appears to have seated itself and not leaking !! any feed back as to is this a pressure release valve and bleeder or is my diaphram taking a **** and bypassing fuel to external plastic casing ?? runs fine and no leak ? so far havent taken it out on the water yet ?? thanks crazy eddy
flyingscott
Is this a disabled VRO pump? Is the cap on the main fuel fitting for the motor.
crazy eddy
not sure if it is disabled but the motor ran fine the cap is flush and looks like it was part of the plastic mould /pump but actually was loose ,sort of and felt as if it may have a spring underneath , when i pumped the ball fuel leaked from what appeared to some kind of cap after tapping lightly I ran the motor in the drive on ears and the leak is gone and cap seems to have sealed itself if it is a cap or breather I dont know it is in between the 2 part pump ??? any body familiar with this thanks crazy eddy
