87 Johnson 120 v4
GeeTee
Hi guys and girls
I`ve had the motor for a while now and she runs really great. Ive gone and replaced fuel lines, decarbed the cards, new spark plugs new cdi (only because i had other issues) - now the question is, although she runs great i don't seem to get max rpm. I have a 19" Stainless 3 blade prop on her. I reach about 4300rpm - then i can open the throttle to WOT and no RPM increase. It doesn't seem to be spluttering no loss of power when at WOT just NO additional RPM. I`m thinking she should be able to get to 5200 without any issues, am i right or expecting too much? Fuel pump at high rpm not providing enough pressure?
Cheers for now
Bob_VT
Greetings and welcome to iboats.
One of your cylinders is NOT firing and you are actually running on 3/4 of the cylinders.
Use a timing light and check to see if one plug is not firing. You have a bit of troubleshooting ahead and I have been down the same road. My situation was a bad coil and a bad power pac that was also not working properly.
GeeTee
Thank you for the welcome and the response!
Given my limited mechanical knowledge i would not even have thought about that, i would have thought that having one dead cylinder would would affect the performance alot more ie, rough idling, not getting onto plane etc. Part of the reason i`m on here, to learn ;-)
While i was messing around i did a compression test, all cylinders sitting at just about 130psi - this seems really good - very happy about that. Seems i have a firing/spark issue.
I`ll take a look at spark and feedback - thanks again for the advice.
TD_Maker
Bob has much more experience that I do, but I have a couple of simple ideas which may help you. Pull all your plugs....the plug that looks wet is the cylinder that is not firing. Make sure the spark plug wire has not come loose from one of the 4 coils. Try switching around the coils (to different cylinders) to see if the dead cylinder problem follows the suspected (bad) coil. If it does, then you have found your problem.
GeeTee
Ok, that makes sense. I have however seen when i did the compression test on the cylinders that all my plugs are "wet" around the thread area, i believe they`re supposed to be wet in a 2 stroke to a certain degree or is this not the case?
Bob_VT
Wet? Wet with? Water or fuel/oil mix. Lets solve the 1st troubleshooting issue. [okay you could have a bad head gasket if it's water and gas/oil is normal because when you switch the motor off the motor spins and sucks the gas/oil into the cylinder.]
I use a timing light that has a simple clip that goes around the wire. When the motor is at an idle (and on muffs) I look at the light that is being flashed. It will appear rhythmic and if you idle u p it will just increase. Repeat that for all 4 cylinders. If you find a poor erratic light then swap that coil to the other side of the engine and test again. If the problem follows the swap then the coil is bad if the problem stays on the same cylinder then the power pack for that side is bad.
A V-4 will sound fine and even "rev" up with 2 cylinders firing (it's bad to rev the motor in neutral). No one has ears good enough to hear a dropped cylinder.
You have great compression ;)
