'87 Force 50hp electrical question
Tobasco
Hello to all. I'm new to this site, but have really enjoyed reading all of the post and comments for sometime now. Now to my problem and question. I recently purchased an '87 50hp. Force, and am not familiar at all with this engine(I've always owned Mercury's). The engine runs great, and performs well on a 17' aluminum bass boat. However, the depth finder shuts down constantly if RPM's are higher than idle. After doing a diagnostic check on the depth finder, it showed "high voltage detected". I understand that this engine has a rectifier, instead of a regulator. My question is this, can I safely install a voltage regulator to drop the voltage output. Thanks in advance.
12Footer
Re: '87 Force 50hp electrical question
Yes you can, and it is adviseable, as it will surely fry your battery on a long, daytime trip. The battery will charge at the 18+ VDC that the stator delivers.<br />I used the board out of an old automatic battery charger. It came ready-made.
