87 force 125
fish6221
I have an 87 force 125 and had some issuses with the motor not going into gear. we found the linkage under the carbs had the nut back off. fixed the linkage and so on.... now the bushing/bearing on theinterlock arm is bad. looked on ********** and found the parts diagram but the bearings say obsolete. is there anywhere i can find these parts?
Frank Acampora
Re: 87 force 125
If you mean the white nylon bushings, they probably can be found at Home depot or Lowes in the drawers of screws and specialty parts.
fish6221
Re: 87 force 125
is it a pain to remove this bolt that holds the bushings? it is in a tight spot lol.
Frank Acampora
Re: 87 force 125
Not too bad! The bolt head usually is kept from turning by the bracket. However, for ease of removal wedge a screwdriver blade between the head and bracket while you back off the nut.
