Re: 87 force 125 engine mounts
You actually don't have to pull the powerhead on that motor. I just did a powerhead swap on my 1989 Force 120 this weekend(used an '88 125 for the head).<br /><br />Remove the cover on the leg that's towards the rear of the motor. 6 - 1/2" bolts. That will expose the two main bolts that go up into the mounts from underneath. You'll also need to pull all the bolts from the lower cowl on the boat side of the motor (about half of them). They are the bolts that if you remove your engine cover and look down, they run all along the outside of the block.<br /><br />At that point, the motor is free. Either use a hoist or a friend because it's heavy!! Basically, the motor will come off complete, leaving the mount and one trim piece hanging on the boat.<br /><br />Oh, and don't forget to disconnect: wiring, fuel hoses, steering, shift/throttle linkage, etc. Unless you've got 3 feet of slack in everything and can have someone hold the motor while you swap mounts
