1987 Evinrude 20 hp model#E20CRCUR
Back story:
This is my first outboard, and while I am not a mechanic, I have done a lot of work on cars. I bought an impeller for routine maintenance. While out fishing a few weeks ago, my fishing partner broke the pawls on the rope start. When we got home early, I started on replacing the impeller. Bad idea, since I couldn't test the motor to make sure everything worked. Well, i didn't get the water tube lined up correctly putting the lower unit back on. So, after I finally recieved the pawls and springs a week later, I put them on and tested that they were catching the flywheel, completely forgetting that I hadn't tested the water pump yet. Yep, you guessed it, I didn't notice the lack of tell-tale and we overheated.
The problem:
I overheated the motor. The engine didn't seize, but the top cylinder has some scoring by the exhaust port. Testing the compression cold (since it wouldn't start), I got about 10 psi in both cylinders. I bought a new head gasket, exhaust cover gaskets, cylinder head cover gasket, and bypass cover gasket (not yet installed), and thermostat. After installing all but the bypass cover gasket, I got 45 psi in both cylinders.
The question(s):
I'm going to replace the bypass cover gasket this weekend, but if that doesn't do it, what's next? Would scoring on one of the cylinders cause the compression to be identically low? Seems to me like that would cause only the top to have low psi. Are the rings just shot from overheating? Can I just replace the rings on both, or would I need to replace the top piston as well? How much scoring can be there before the cylinders need to be bored? Should I just part it out and move on?
Thanks in advance for any help. I tried to upload pictures through the exhaust ports, but the site won't let me.
Back story:
The problem:
The question(s):
