87 8 hp Johnson midsection leak
CaptDave101
I have an 87 8 HP (8RLCU) leaking on the front side between the lower gearbox section and the 5" long shaft ext. It appears there are a couple of weep holes on the front of the midsection on each side where is it coming from. Was wandering if this is a bad seal or if this is just oily exhaust making its way out. I have a couple pics but am new to the site and get an invalid file data error when trying to upload. Any insight is appreciated.
CaptDave101
OK, here is the picture of the "weep hole" where oil is seeping. Front of the midsection between lower gear unit and 5" long shaft ext piece.
Vic.S
Almost certainly just unburnt oil from the fuel.
Perfectly normal esp after a period of slow running or running in a barrel.
See the item entitled "Oil leaking around lower unit" on the Engine FAQs board
The only time to be concerned about oil leaking is when it is gear oil that is leaking.
Honorary Supreme Mariner
That leak could well be normal exhausted oil on a 2 stroke engine.--------The lower unit on those can not tolerate water intrusion.------Just for your information.-----The shift rod has one o-ring for a seal.-----I install 2 o-rings in there just because there is room for 2 of them.------Bigger motors have gone to 2 o-rings as well.
CaptDave101
Vic and racer, thanks for the experience lesson. I failed to mention that the motor was new to me. The previous owner put the outboard in a barrel the night before I came over to prepare for the test run. Comments on the barrel and idling were spot on. I will verify that there is no oil in the gear case when I change and put two O-rings if I have it open. Thanks again.
Vic.S
Its a good idea to check/ change the gear oil on a "new to you motor" , fitting new nylon sealing washers to the drain and level screws.
Also , unless you know its been done recently, to fit a new water pump impeller
Perhaps as it is new to you it would be a good idea to mention that the correct fuel mix is 50:1 even if the original manual and decals say 100:1
