87--60hp Evinrude warning buzzer
ssdd
just bought 87 -60hp Evinrude but the warning buzzer in shifter is buzzing. What is this telling me ? looks like good water flow --seems like batt. was low. it is not oil inject
wilde1j
Re: 87--60hp Evinrude warning buzzer
VRO or not? Could be overheating, or oil low, or not flowing. If no VRO, it's hot horn.
seagull369
If buzzer goes off immediately after cold start, There might be a problem with its related temp switch mounted to the engine. Might be shorted to ground continuously. <br /><br />If buzzer goes off after only after a while of running engine, it may be more likely that your engine is not receiving enough water to cool it down. This could be from a worn water pump, or blockage somewhere in system.
