87 50HP johnson need some help
beto
Will a bad water pump cause it to sputter at low speeds? At high speed it seems to kick in and water flow looks fine. :confused:
Re: 87 50HP johnson need some help
i have the same problem with my motor only 2 years apart i got a 85. 50 hp i was told they always run rough when low speeds but when running it goes great
Nathan k
when did you replace the impeller?
also it would need minimal cooling anyway at a low speed
jigngrub
Do you know when the last time your impeller (water pump) was changed? Puting a new one in won't hurt a thing, or at least inspect your old one. Better yet, if your old one looks ok just save it for a spare and go ahead and put the new one in.
You can get help on how to change it in the Johnson engine repair forum.
beto
I bought and have had the boat in the water since April. I had some issues in the with the fuel system, but have since replace all the fuel system including removing the vro pump and modifieing a bracket for a regular fuel pump. It had been running great the last three or so months till last Sat. I was heading out full throttle and it just startd sputtering. I noticed it was not spitting the same amount of water that it usually did. So I figured it could be the pump. At full throttle it sputters a little but then gos and water seems to flow right. At low speeds pulling in to my slip or just crusing speed it sputters and water does not flow right.
Edit Post Reply Reply With Quote
