Not familiar with that engine but the whole starter bracket needs to come off. Usually 3 bolts. May need to remove 2 small bolts from the throttle shaft mount as well. Which is what I have to do on my 94 30hp Johnson.
Disconnect battery.
Remove two screws holding the clamp that goes around the shaft behind the starter.
Useing a 3/8" swivel socket on a 1/4" drive extension remove the bolt that goes in forward facing on the bottom of the bracket behind the starter. It is hard to see but is under the start solenoid.
Remove the bolt at the top of the bracket that goes in sideways behind the starter.
Remove nut on the stud on the front of the bracket.
Remove the positive wires from the solenoid.
Carefully pull starter and bracket forward to clear stud.
This should give you enough room to get a 1/2" wrench on the port carburetor mounting nut.
Hope this makes sense. You could also look up the exploded diagram at BRP. I think you need to look under the Cyl&Crank tab.
