87 175 Johnson vro
Mikered3500
Bought a boat with this motor, just got it running again, they had the thermostats off and never changed them...had it on the hose for the start up .the port side got warm pretty quick and had clean water coming out of the thermostat port. Starboard side took forever to warm up and had milky exhaust filled water coming out of that bank. Any suggestions?
Faztbullet
Need to do a compression test. Does it has the bubble exhaust??? If so these are bad about scuffing cylinders due to sleeves being so thin.
Mikered3500
I did a compression cold and hot. The numbers are slightly higher hot. Lower 2 cylinders were 85-86, middle were 88-89, top were 90-92. What do you mean bubble exhaust? I'm new to the outboard world
Bosunsmate
Bubble exhaust has a bulge at the back between both sparkplug banks, the flat one is flat.
Id check that its firing on all cylinders
Rustywrench
Pretty sure 1986 was last year for big block motor? Guess we need a model number to be sure what we are working with.
Mikered3500
Oh yea .it looks like an oil pan kinda? We did a spark test with a test light and then pulled all the the plugs and checked it that way as well. All we're dry and had a pretty good lighting bolt shooting off of them. I can post a model number when I get off work today.
Mikered3500
There is kind of a slight miss or idk what exactly you would call it at idle every 10-15 seconds. Is there any way to add a video to these threads?
Bosunsmate
Maybe but most people just add a youtube link.
Check your pistons domes through the sparkplug holes. It may be a water leak in which case the dome will be clean looking
Rustywrench
You got me again racerone! I just don't remember these things like I use too. I knew the CF went away in '91. Thought the big bore went away earlier. Should have! Built 60* & CF at the same time for 1 year. Confusing.
Mikered3500
The Pistons look normal colored after being ran, dark 😂 but no signs of water or anything getting into the cylinders. The plugs are looking good as in not fouled or anything, no signs of water getting on them either . I'm clueless as to how the exhaust is getting in the water. Any chance it's a head gasket issue even with decent compression???
Bosunsmate
Yes. Try running it with one of those starboard plugs out in turn and see if you can narrow down which cylinder makes it "milky"
