86 Mercury 35hp help
Darin-C
My 86 35Hp Merc. does not seem to be running at full power. Any suggestions on what to check or look at?
last year I had the motor tuned after I got it, not sure what all they did. Hunted in it last winter and it ran good.
This spring I did a seafoam treatment on the motor.
replaced the water pump impellar and I cleaned and rebuilt the carb.
and I have replaced the plugs.
After all that it ran great all salmon season for me. I have put 40+ hours of trolling speeds on it since then.
this fall it does not seem to be able to get me up to the speeds I had this summer, it has dropped of 4-5 MPH at full throttle.
any suggestions? is there something else to do on this besides what I have done?
Thanks, Darin
bgbass.1
Re: 86 Mercury 35hp help
If above comments ok could be carb. dirty got some bad gas with all that trolling it will load up.
Laddies
Banned
I think bgbass is on the right track sounds like a fuel problem
Darin-C
compression check
spark check
I Checked the top Cylinder and it was 150psi, have to get an adapter to check the bottom cylinder due to the cowling.
What should the difference be between the cylinders?
I will change out the gas.
What should I look for or how do I check the spark issue?
