matt_rad73
Thread starter- Joined
- Jul 13, 2009
- 7
Ok I have tested and retested this problem. Everything for the adutls only troubleshooting ingintion thread. Coil, rotar and cap have been replaced points look like new. If I use a spark tester from the coil to ground, At the moment the key is turned to start there is a small spark and then for as long as you crank the motor no sparks. As soon as you stop cranking the motor a very weak spark is noticed also.
Any ideas?
Matt
Any ideas?
Matt
