86 Merc 8 hp idles only with choke on partially
Roger T
My motor starts up Ok but only runs with the choke partially on. If I put it in gear and full throttle it will run without the choke. As soon as I decrease the speed the motor stalls.
Fuzzytbay
Re: 86 Merc 8 hp idles only with choke on partially
Sounds like not enough fuel. Choking makes the fuel mixture richer, ie more gas. I'd look at your fuel system, fuel pump, carbs, ect.
Roger T
Thanks for the reply.
I looked at the choke linkage and there is a cam that I adjusted. It increased on the movement of the buterfly valve in the carb which increased the idle speed by increasing the fuel.Then I richened out the mixture :)a little.
It is working good in the tub so back to the boat with it.
