86 Merc 20hp won't shoot water
stets
My motor starts on the first pull, but no water coming out.
I just changed the impeller and all the seals that came with the kit.
Whats next?
Thanks
Stets
buster01
Re: 86 Merc 20hp won't shoot water
Check the impeller key, it may not be installed.
Just a thought.
Wingedwheel
Are you trying to pump while in the water, at tank or on a hose with muffs?
Mi duckdown
was it pumping water before you installed the new impeller?
did you rotate the driveshaft clockwise when installing top of pump housing?
is the copper tube seated in the upper and lower tube seal?
stets
Thanks for the tips, it turns out the copper pipe
wan't seated properly
