86 Merc 200 hp Trim Wiring Diagram PLEASE!
One Fast Spectra
I really need help with a wiring diagram for trim/tilt
86 Merc 200 hp
3 wires Green-Blue-Black with big rounf eye holes from the trim motor
4 smaller wires from the controls Green-Blue-Purple-Brown with smaller eye holes
This is driving me nuts, I am low on funds, (who isn't) and the shop wants a budle! :redface:
blazer01
Re: 86 Merc 200 hp Trim Wiring Diagram PLEASE!
i have the same style i will take pictures tomarrow... Please send me a pm due to the fact I may get busy and forget
blazer01
ok here are the pics aswell i emailed them to you
One Fast Spectra
Really need HELP with trim wiring. Got power head rebuilt last year and didnt lable these wires. UG! :(
My enging number is A914000 and it is idicated as a 1986 Merc 200 HP.
From the controls:
Four thinner wires- Brown-Purp0le-Black-Green
From the trim motor:
Three thicker wires- Green-Blue-Black
Here is a picture of where the wires should go, I just do not know how to wire this up.
blazer01
From the controls:
you should have 2 solonoids for the trim can you post a larger picture?
One Fast Spectra
That's whats srtange, only looks like one solonoid, copared to your two and others I have seen.
The enging mumbers do indicate 86 merc 200 HO extra long shaft. This was Mike Avilas off shore race boat and had twin mercs in the 80's.
blazer01
do you have a trim button on the motor it self?
One Fast Spectra
No, ONE solenoid and trim is on controls up front. We by passed and the trim works! Step one.
Now I know that the power head was replaced and may not be what the tag on the mount indicates, 86 200 hp.
Someone said there is another serial number "behind" the flywheel? Where?
One Fast Spectra
Here is a LARGER picture, ONE solenoid! :eek:
blazer01
It would be on top of the block right behind the flywheel it's about the diameter of a quarter right above #2 cylinder.
that solonoid you see is your starting solonid..is there any others? if possible could you get a little bit bigger picture..as well if you need a replacement intake tube( i noticed yours are broken) i have a couple of them
One Fast Spectra
Hey thanks! I have been out of town, so I will look tomorrow. We did by pass and all the tilt trim works fine, a good start.:D
