86 johnson need help
oww2
I have an 86 johnson 6hp. It is leaking from the carb bowl. I have replaced the gasget, but it still leaks. Also when i throttle up it seems to miss or it will just die. If can can help plz do.
JB
Re: 86 johnson need help
The float is probably set too low or the inlet needle is leaking, oww2.<br /><br />Get a Service Manual and overhaul your carb.<br /><br />Good luck. :)
