86 Johnson 90hp
mypoleisbent
New to this forum and have several questions. First one;<br /><br />I just purchased a this 90hp motor, Previous owner replaced the thermostat supposidly.<br /><br />Motor will run 10mins or 1hr or anywhere in-between. It will then stall like not enough fuel. Immediately you can re-crank the motor, but it wont start. 10-30 mins of sitting and it will restart and run fine for 10 mins -1 hr then same thing again. Motor can idle all day long in yard in barrel without this problem, even in Neutral @ 1000-2000 rpms no problem in yard.<br /><br /> I have not gotten the motor installed on my boat yet, this is just what I am being told. I bought it from a friend, I asked if it ever overheated he said no, and that the first time it happened he pulled the plugs and didnt have any problem handling the plugs and they were not fouled.<br /><br /> WHERE do I start??????<br /><br />Next question is how do you test the overheating horn to ensure proper function?<br /><br />Last question is;<br />can I install....<br /><br />temp gauge?, trim gauge?, h20 press guage?, fuel press guage?<br /><br />on this motor?<br /><br />Thanks.
snapperbait
Re: 86 Johnson 90hp
"WHERE do I start??????"<br /><br />Buy a service manual, if you don't already have one..<br />New water pump and thermostats.. <br /><br /> To test the warning buzzer, touch the tan temp switch wire (temp switch located on the cylinder head) to ground.. Horn should sound... <br /><br />You can install a temp gauge, water press gauge, and a trim gauge... Fuel press gauge, I guess, if you really wanted one..
mypoleisbent
Re: 86 Johnson 90hp
So if the outboard's tell tail was present, and it can immediately crank after it stalls, are you thinking overheating or fuel related problem here?
snapperbait
Re: 86 Johnson 90hp
As for the fuel side, when it stalls, is the bulb hard or do you need the pump the bulb?<br /><br />Make sure the vent on the tank is open and clear, maybe try a different portable fuel tank..<br /><br />If you can verify fuel in the carbs float bowls when it quits, look for electrical gremlins.. Messed up kill switch, bare wire somewhere, bad ignition switch, maybe even a powerpack...
