OzzmysterG
Thread starter- Joined
- Apr 1, 2002
- 9
please - please - someone tell me there is hope! I rebuilt my engine but forgot to put the o-ring on the cooling shaft (in the block) - and had someone finish off the final touches (electrical and tune-up. He informed my the cooling shaft wasn't held in place, and he used (jb?) to hold it up there, but that I should replace my impeller. Well, i went to change it today, and my cooling shaft fell from my block. Is it possible to take the power head off (8 bolts from below) and successfully put the o-ring back on to hold it in place?<br /><br />Also, when I went to change out my impeller - my shaft has a brass ring on the top that is stuck there - and I cant take the impeller up. Do I need to open the lower unit and disassemble to remove the impeller from below?<br /><br />Thanks -<br /><br />Oz
