nabularach
Banned
Thread starter- Joined
- May 18, 2008
- 52
My tilt trim seems to work fine but hen I put my boat in reverse the motor lifts out of the water if I have the rpm's too high. If the motor is in the don position I can lift the motor right up. I tried to check the manual relief valve but it isnt a screw it is kind of a plug held in by a spring clip. Can anyone explain this? The other thing I noticed is that there are 5 holes to connect hydraulic lines to the pump but there are only 4 hooked up. 2 go to tilt and 2 go to trim the other hole is threaded but it is not plugged. My guess is either the spare line should be plugged, the check balls in the pump are out of round or a seal in my tilt cylinder is bad. These are just guesses at this point and I would appreciate the opinion from someone with more experience.
