outboardretard33
Thread starter- Joined
- Jul 17, 2009
- 5
I previously had problems getting into reverse. Mr. Acampoa gave me directions on how to adjust the pivot screw, shift linkage after I removed the pivot screw to drain the gear lube. I didn't get a chance to use the instructions, before a semi-trusted outboard mechanic, removed the lower unit and replaced the shift dog. He said the shift dog was pretty worn, but that the rest of the gears looked good.
My question is how much should parts and labor be to replace the shift dog. He didn't replace the water impeller - said it looked good. He charged me $340. It was a little hard to part with the cash. But for as old as the motor is, I think this was a good deal. Or did I get taken to the cleaners? What do you think?
