nabularach
Banned
Thread starter- Joined
- May 18, 2008
- 52
I had the boat out last weekend and after a few hours I was running about 3/4 throttle when I noticed a noise that sounded like a valve tap then it quickly got louder and stopped the motor so I got towed in. At the marina I pulled the head and the cylinders appeared to be ok as far down as I could see. When I rotate the flywheel i seem to hit a spot that I cant get past. I am assuming it is a rod bearing. Any one have any thoughts?
Thanks
Thanks
