86 Evinrude Johnson 50 hp VRO
vtec4max
When I start my motor it would run for like 10 seconds then died. But if I push the key in to prime it momentarily then it would stay running but only for a short time. If I don't keep doing this routine it will stall. Any idea or suggestions? Thanks in advance.
vtec4max
Disassembled cleaned with carb cleaner n shot compressed air thru the jets. Reassemble, installed and same thing. There a unit might be called fuel demand reservoir looks like a fuel filter. Does that have to stay full as the engine runs? It seems like when I prime it, it fills up. Then when it runs it emptied out but when I disconnect the fuel line fuel shot out of it. I just can't seemed to figure what's wrong with it. Because it runs good at high speed, just low speed that it stalls.
